brake light switch wiring - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-22-2009, 11:13 PM
tjn tjn is offline
tjn/56nomad
Hey guys, I have an AAW harness in my streetrod that was partially "rigged". Can't get the brake lites to work. The switch has a white and blue wire connected to one side of the switch but nothing is connected to the other side. I can't seem to find an extra plug. Help please! Thanks, TJN/56NOMAD
Old 05-22-2009, 11:17 PM
I have found over the years that some models that have the brake light switch mounted on the pedal have wiring problems...
this is do to the swinging of the pair of wires with every brake application... eventually the wires will break...
when this happens.. the brake lights will not function.. on later models... the shift interlock will not release... except with the key only part way turned on . pulling the shifter to Neutral the car or truck will then start to get you home... but you may not have brake lights.... a lot cheeper than a tow truck...
to take care of the fatigued wires... stop at a radio shack... they sell small rolls of 19 gauge test lead wire ... replace the last 6 inches of both wires that run to the brake light switch with this super flex wire...
fully insulated crimp on terminals are also available... in both straight on... as every body knows about... but there are also fully insulated flag terminals available.. the wire comes out the back side... these come in handy for some applications where there is limited clearance..
oh... and one more... every once in a while... a car or truck will come along that the brake lights just don't come on with light pedal pressure... you really have to mash the pedal to get them to work... swapping out brake light switches really does not help much... putting a thin shim between the back of the brake pedal push rod and the inside of the switch usually fixes this... shim stock.... think a slice of soft drink can cut with scissors. pushed in... wiggled in. usually you have to gently rock the switch up and down to get it in.. bend the short ends over slightly to hold it in place.. but make sure the ends are not long enough to short out anything... in the years i have been fixing cars .. i have only needed to do this on 3.. but the customers were going out of their mind with late to work brake lights...
hope this tip helps some people...
here are some part numbers
conduct tite 85556 for red, straight on fully insulated connectors
conduct tite 84170 for red, flag fully insulated terminals
oops. just checked with radio shack... they don't sell the test lead wire in bulk rolls anymore... but some electronic stores may have some... i have seen it in 17 gauge and in 19 gauge ...odd sizes yes.. but it is very fine stranded wire..
__________________________________________________ ________________
www.wasserbettenhife.com
Manager Education
Old 05-23-2009, 02:30 AM
Joe G's Avatar
The other terminal on the brake light switch should have an orange wire marked 'brake feed' that goes to the fuse panel. This is the power feed to the switch.
If it's a 'Highway 15' or 'Highway 22' wiring kit, there is a screw terminal for the brake feed wire on the fuse panel.
Hope this helps....
Joe G.
Old 05-23-2009, 08:01 PM
tjn tjn is offline
tjn/56nomad
No brake lights
Thanks Joe G! TJN
Brake light problem mightycarlo10 Electrical 6 12-18-2007 05:43 PM
72 chevy light switch wiring gottahavetoyz Electrical 2 09-17-2006 03:26 PM
Brake light switch update 65Stanger Electrical 7 06-14-2006 04:42 AM
wiring diagram for brake light/indicator? pcoghlan Electrical 2 06-06-2006 02:58 PM
mechanical brake light switch colobronco Electrical 2 08-18-2004 05:54 PM
