brake light and turn signal wiring - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-26-2009, 08:01 PM
slammed 57's Avatar
Last journal entry: t
tryin to wire up my brake lights and brake switch which is new, not currently mounted, the turn signals work and light up, ive been tryin to find the wire for the brake lights but can not trace it down. can i run a new wire from the fuse box to the brake switch and back to the lights. i know the turn signal and bake lights share the same wire at the rear brake lights. just curiouis if i can just run a new wire to the lights (which would be easier than spend another 2 hours tryin to trace down the wire) or would i be running into problems by doing this , Thank you, mike
Old 10-26-2009, 08:32 PM
302 Z28's Avatar
What kind of car are you working on
Vince
Old 10-26-2009, 09:26 PM
I don't know if this will help or not, but I was wiring my roadster and I could get my turn signals to work, but not the stop lights and vice-versa. I finally took the brake light switch wire and connected it to the 12 volt side of the flasher and now they work like a champ!!!! I did all the wiring from scratch using a GM steering column. I used a pressure type brake switch. Hope this is some help. You still really need to locate your brake switch since that is the only thing that will operate the lights. Your user name may be a clue (slammed '57), but normally, there is a switch attached to your brake pedal. Hope this helps.
Old 10-27-2009, 08:55 AM
Frisco's Avatar
Glad To Be Here
See the diagrams below. They might help you trace the wire for the brake lights. The wiring will come from a 'HOT' source to the brake light switch and then to the directional signal switch. The universal drawing may help. The GM drawing is for later model connection block and may not be suitable for your car.
Doing this will have both lights on when attempting to use the directionals. Will not work.
Name:	General Motors Column Connector.jpg
ID:	41578   Click image for larger version
Old 10-28-2009, 07:25 PM
slammed 57's Avatar
thank you all . iam gonna try both advices , we'll see what happens
brake light wiring with an 1156 and 1157 AngliaBob Electrical 3 10-22-2008 08:55 PM
79 TA: hazard, right turn signal, brake signal out Gladis Electrical 6 12-25-2007 11:06 PM
How Does This Stuff Work? docvette Electrical 3 06-18-2006 04:00 AM
brake light, turn signal, tail lamp problem worknprogress72 Electrical 6 01-06-2006 01:20 AM
turn signal and brake light problem PrimeMover Electrical 5 05-27-2003 07:26 PM
