Brake lights - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-10-2007, 07:54 PM
Brake lights
ok i have a 1966 chevy fleetside and the rear left side brake light is having some problems. When i turn on the turn signals it comes on and works fine, but when i press the brake it doesn't come on. I traced the whole freakin brake light wire all the way onto the cab, and found NO breaks in the wire, i can check again but i'm sure its solid, if you have any suggestions on what it would be just tell me and i would be VERY happy, but if not i can jsut bring it into a shop and see if they can find it.
Thank you
TJ
Old 08-10-2007, 08:25 PM
T-bucket23's Avatar
Wiki Edits: 26
Turn signal switch could be bad. The brake lights go through it.
Maybe someone here has a schematic for you.
Old 08-10-2007, 09:19 PM
Cape Cod Bob's Avatar
trhttp://vccachat.org/forum/ubbthreads.php?ubb=cfrm&c=4
try posting your ? here
Old 08-10-2007, 09:30 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Sounds like the Column Plug may be dirty, corroded,or not properly seated..pull, clean, burnish and inspect the connectors.
Next step would be the left half of the turnsignal switch may be bad or intermittent..clean the contacts, inspect the connections (at the switch), and inspect the movement of the "Reset" tang as it returns to the center position..1/2 of that 1/2 of the switch is Brakelamp..the other 1/2 of that 1/2 is turnsignal..the centerwiper is the bulb itself...The whole OTHER half is the RIGHT side..
The switch provides the needed Isolation Between the two systems..
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 08-10-2007, 11:09 PM
hey thanks!! ok tomarrow i will try both of those things and get back to you
voltage to tail lights vs brake lights? stratt134 Electrical 12 06-10-2006 06:51 PM
brake lights stay on.... jmtw Electrical 6 03-06-2005 07:48 AM
Wheel clunking and brake squeal skizot Suspension - Brakes - Steering 29 10-09-2004 06:17 AM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 03:34 PM
Brake Lights 53chev Electrical 4 12-10-2002 03:49 PM
