Brake lights blowin fuses - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-15-2005, 04:59 PM
Scotts67's Avatar
New Member
Blows brake light fuse (20 amp) whenever brake pedal is pressed. Car is a 67 Camaro, basically stock. Turn signals work (front and rear), parking lights work (front and rear), headlights good, good ground at dash and bulbs (I believe since signals work), have correct 1157 bulbs in rear. 12+ volts on one of two terminals at brake light switch. Any ideas would be appreciated. And no, I'm not throwin' in a larger fuse
Old 06-15-2005, 06:23 PM
BigDawgsEatFirst's Avatar
400SBC4Life
Try this out
Anything else on brake light fuse.
1.Bad ground in brake light socket
I had a light doing that
and i had to replace the socket with another one
Then it worked,no more problems.
Old 06-15-2005, 06:57 PM
Scotts67's Avatar
New Member
Thought maybe not grounded good, so I reground the buckets to the housing, good ground for sure, but still blew a fuse when applying brakes!?! Thanks for the idea though, any other ideas? Getting annoyed with this...
Old 06-15-2005, 08:43 PM
docvette's Avatar
Wiki Edits: 12
Fuse Blows
Doc here,
Remove the wire from the switch that doesn't have power on it..
Install a good fuse and step on the brakes..does it blow? If so it's between the switch (or in the switch) and the fuse ...troubleshoot that wire..
If it Doesn't blow a fuse..
Remove the Bulbs...
With an ohm meter, set to R x 1 K read Between that wire and ground..It SHOULD be infinite...If it is not, you have a short between the switch and the rear harness, most likely where it goes under the seat through to the trunk area..or snagged on the spare tire..
You may have to hand over hand the harness to find it..
As a last resort, (because you say the T/S are good) you may have to check the brake lamp wires as they enter and exit the column.. but as you say the turn signals do work..so should the brake lights...
Here is the schematic for a 67 Camaro...you may have to print it out to read it sorry..Scanner is dying out...
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 06-16-2005, 07:26 PM
Scotts67's Avatar
New Member
Ok Doc, thanks for your help so far... With only hot wire hooked up, new fuse, brakes applied it does not blow a fuse question, on a 2 wire brakelight switch, the orange is hot 12+ volts, other wire is white, in your opinion should this wire be grounded? It is and I'm thinking it shouldn't be (per your and my wiring diagram), want to be sure before I hook them both up hot, but dealing with previous owners hack job (actually professionally installed but I don't have schematics) of a car alarm installed . And as you know this cuts into all light sources. You've been a great help again thus far and hoping you can elaborate a bit on this. Thank you Doc.
Old 06-16-2005, 08:22 PM
docvette's Avatar
Wiki Edits: 12
White wire
Doc here,
If you removed the bulbs, the resistance on that line should be infinite to ground...
With the bulbs in, It will read a few ohms to ground (the filament loads) , this is why you need to remove the bulbs to insure the harness really isn't shouted to ground.
If, with the bulbs removed you have infinite readings you should be OK to hook power up to them...In fact, Try that and see if the fuse blows..
If it doesn't, and then does when you put in the bulbs , you have a shorted socket...(install one at a time until the fuse blows..that will be the bad socket..)
You might want to pull the plugs on the alarm box while testing to eliminate that as a possible source of ground also..
Doc
Innovations
Old 06-17-2005, 11:06 AM
sedan delivery's Avatar
blown fuses
if the signals work ok, check the white wire going from the brake switch to the signal harness, this wire could be shorted to ground. eather from rubbing or pinched in the column. the power goes from the brake switch through the turn signal switch then to the brake light bulbs. check the white wire.
Old 06-17-2005, 09:19 PM
Scotts67's Avatar
New Member
You the man! After fighting this thing forever It was that damn white wire. I hadn't noticed the brake lights/dash lights not working since I've only taken it out in daylight... The previous owner had an alarm installed and teh white wire comming off the brake switch was straight to ground (explains the 18 fuses I went through testing the last few days) I located the original white wire (lost up in dash) and reconnected and WALA, got working brake lights!!! All lights working now so I can "safely" take it out now this weekend. A big hardy "THANK YOU" to you and Doc for all the help, I owe you a cold one of your choice (actually owe you a hellofalot more than that) but it's all I can do for now. God Bless this BB!
Old 06-18-2005, 05:30 PM
docvette's Avatar
Wiki Edits: 12
The Fix
Doc here,
Thanks For Posting back With the fix! It may Help the next Guy!
Glad To hear you Found the problem!
Good Call there, Sedan Delivery!
Happy Rodding..
Doc
Innovations
brake lights stay on.... jmtw Electrical 6 03-06-2005 07:48 AM
Wheel clunking and brake squeal skizot Suspension - Brakes - Steering 29 10-09-2004 06:17 AM
96 MonteCarlo No brake lights Ronald Bredeweg Electrical 4 11-12-2003 12:05 PM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 03:34 PM
Brake Lights 53chev Electrical 4 12-10-2002 03:49 PM
