Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Brake lights, head lights
Old 04-30-2006, 06:06 PM
vicrod's Avatar
vicrod vicrod is offline
life is a ride
Last journal entry: LED tail lights
Before you replace the brake-light switch do this test.
Disconnect the (2) wires that connect to the brake-light switch and jumper them together.
If the brake lights work the switch is bad.
If the brake lights DO NOT work, look elsewhere. Fuse, bad bulbs,turn signal switch, mouse ate the wires....
vicrod
