Brake lights, head lights - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-30-2006, 06:02 AM
I have two more questions. I have my rear tail lights working but no brake lights. Is there a switch somewhere Im missing? Second, my car was disassembled when I bought it. I cant figure out where the head light wires connect to the harness. I see there is a junction box on the drivers side inner fender well is this what I should be looking at?
Thanks in advance
Old 04-30-2006, 10:57 AM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
The headlights probably hook up to the junction block. On my 51 chev pickup that is where they got their power from. As for the brake lights, there should be switch on the master cylinder, sometimes these don't work. You will have to test it.
Here is link to a site with old chevy manuals on line. You can download the 1941 manual and I am sure most of your car is the same.
http://chevy.tocmp.com/
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Old 04-30-2006, 03:53 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
You may want to check the brake pedal linkage above the dash for that switch also..
Doc
Old 04-30-2006, 05:16 PM
Its a pressure switch on the master cylinder, I have a new one but didnt feel like bleeding my brakes after changing the switch. I got the head lights working thats enough for today. Thanks guys. The link to the manual was a big help!
Old 04-30-2006, 06:06 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
Before you replace the brake-light switch do this test.
Disconnect the (2) wires that connect to the brake-light switch and jumper them together.
If the brake lights work the switch is bad.
If the brake lights DO NOT work, look elsewhere. Fuse, bad bulbs,turn signal switch, mouse ate the wires....
vicrod
Old 04-30-2006, 06:54 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Or you could continuity check across the switch, with the brakes off, it should read infinite on a DVOM, set to R X 1 Ohms scale, calibrated to 000.
Then have someone step on the brakes , It should read 000.
Doc
Old 05-02-2006, 01:07 AM
Just a follow up, I ended up replacing about a foot of wire to the pressure switch and the switch itself and I have brake lights!! I took it out for about a ten mile trip today and it ran pretty well.
Old 05-02-2006, 04:29 AM
docvette's Avatar
Wiki Edits: 12
Doc here,
KEWL! Glad to hear you found and fixed the problem!
Thanks for posting back on the fix!
Doc
Last edited by docvette; 05-02-2006 at 04:30 AM. Reason: I before E ..except after a 12 pack
Old 05-02-2006, 11:54 PM
home brew's Avatar
Good to hear you got your lights working. Thanks for the update. When you took it out for you trip was it dark yet?
Old 05-03-2006, 08:59 AM
Yes it was dark, I took it out at night. Brights,dims ,tail lights and brake lights worked. Im very happy. We are going to take it out this Friday night to a place called "Winks" people meet there with classic cars. Thanks again for all the advice everybody.
Brake light problems RodFather Electrical 3 07-29-2005 10:45 AM
Ranger Brake Lights nova69 Electrical 2 09-01-2004 11:50 PM
Short brake lights no signals(possible rewire) 78 monte Electrical 14 09-24-2003 09:44 PM
Brake Lights wont Light! 97 Mustang GT Electrical 4 07-01-2003 11:41 AM
frenching head lights rot_n_rollzombie56 Body - Exterior 4 02-25-2003 04:31 PM
