brake lights not working - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-14-2012, 01:53 PM
GMR GMR is offline
I have a 1964 chev. If I take the switch out of the loop, the brakes lights work (i.e. I disconnect the switch's output wire and apply 12v to the wire the brake lights immediately come on).
If I isolate the switch, it too works (i.e. I disconnect both switch wires and apply 12v to the input terminal of the switch and I step on the brake and I see 12v on the output terminal of the switch).
If I then reattach the switch wires and step on the brake, I see 12v going into the switch and nothing on the output side.
I'm guessing here - the switch will work under a no load situation but cannot handle the required load of the brake lights and needs to be replaced?
Old 11-14-2012, 03:54 PM
EOD Guy's Avatar
Remove the switch from the bracket, leave the wires attached, and see if it works....... if it does then you have to adjust the travel of the brake rod/sheft etc..... to the switch it's self
Old 11-14-2012, 06:35 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
You are correct. The switch is bad. Loose internal connection, corrosion or dirt. Just replace it.
vicrod
Old 11-15-2012, 11:00 AM
GMR GMR is offline
Thanks fellas, yep, switch was bad.
Front parking lights come on with brake lights valtiel43 Electrical 9 03-06-2014 04:55 PM
head lights not working daveid Electrical 7 07-22-2008 05:03 PM
voltage to tail lights vs brake lights? stratt134 Electrical 12 06-10-2006 06:51 PM
LED tail lights, third brake lights ? 1 Day Electrical 6 02-18-2006 06:33 PM
Idiot lights not working... flipp121 Electrical 4 07-03-2005 12:03 AM
