brake lights stay on.... - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-28-2005, 02:37 PM
New Member
Hi guys.
On a 1990 Z71, the brake lights are staying on.
I checked the brake light switch, and it's working.
This is my son's truck. I think it all started when he had to lower the steering column to install a new brake booster.
I figure something got pinched or something, but can't find the problem.
I checked the brake light switch wires, and when it's depressed, only one has juice, so that leaves out one of those wires being pinched.
oddly enough, on the fuse box, the fuse for the brake lights doesn't get juice until the key is on. can someone explain this? odd, because you don't need the key on to make brake lights work. BTW, the brake lights are staying on regardless of what position the key is in.
anyway, any help is appreciated
Old 02-28-2005, 02:49 PM
302 Z28's Avatar
I had that problem once when my 90 Chevy truck was still in warranty. It was the anti-lock module. Glad I didn't have to buy that sucker.
Vince
Old 02-28-2005, 04:35 PM
milner's Avatar
are you sure it's the brake lights that are on. keep us posted.
Old 02-28-2005, 04:49 PM
New Member
wouldn't the anti-lock light be on?
could be that, but seems too coincidental with his replacing the booster and the brake lights staying on. But, that's an idea. I need to check and see if he knocked some wire loose or something.
yup, it's the brake lights.
Old 02-28-2005, 06:48 PM
302 Z28's Avatar
In my case it was not.
Vince
Old 03-01-2005, 04:37 AM
New Member
If I can't figure this out, i'm going to have to take it to the shop (hopefully! they won't say it's the anti-lock braking system ).
I'll let you know what I find out.
Old 03-06-2005, 07:48 AM
dklong's Avatar
it sounds like you have a signal light switch problem.
the brake light switch , goes through the signal light switch, then goes to the brake lights.
the reason why the brake lights are staying on, is usally because the hazzard switch ( 4 way lights ) is screwed up,( I have seen only rear brake lights flash when the switch was turned on or the front only flash ) .
when you depress the brake pedal and only one brake light comes on and the wiring and the bulb is good , this is an other indication that the signal light switch is bad.
the brake light fuse has power all the time. the fuse you are looking at mite be the antilock brake fuse.
58 Chevy Apache : Brake Lights / Wiring Harness Rathimis Electrical 3 12-13-2005 08:34 AM
Wheel clunking and brake squeal skizot Suspension - Brakes - Steering 29 10-09-2004 06:17 AM
96 MonteCarlo No brake lights Ronald Bredeweg Electrical 4 11-12-2003 12:05 PM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 03:34 PM
Brake Lights 53chev Electrical 4 12-10-2002 03:49 PM
