Brake line components ?
Folks, I have a 1950 Ford Sedan. I have installed a street rod engineering front clip with Mustang II front suspension. It has the 11 inch rotors and 82-91 GM calipers. The rear end is out of a 1974 Comet and is 8 inch with drum brakes. I have a 1990 master cyl and booster from a Bronco II mounted on the firewall. On the Bronco II the main line from the master cyl went straight to the front brakes. the other line off the master cyl went to the proportion valve and then to the rear brakes..I cannot use this valve because it is electronically controlled. Can I buy a new valve and do I need a residual pressure valve in the rear brake line ? Will this combination work?
