Brake line fitting question - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-01-2012, 07:32 PM
daveh's Avatar
Hey guys,
I'm making new steel brake lines and I can only find one brass fitting in the local parts store but they have the steel nuts. Is there a difference between the two beside the rusting of the steel ones. I've always used brass not sure about the steel. What are all of your opinions? Thanks
Dave
Old 11-01-2012, 07:53 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by daveh View Post
Hey guys,
Dave
I prefer steel personally, like connecting the brake lines to brake cylinders, calipers, master cylinders, etc. As does the OMs.
Old 11-02-2012, 06:03 AM
Irelands child's Avatar
With OEM fittings which are steel, you get into double flares. With double flares, you get into correct sealing as well as strength which is a plus with using the steel fittings. I'm not sure that you can even purchase a brass fitting that will use that double flare. My recommendation is that you use steel fittings - and yes they will rust, but don't over tighten, don't use any loc-tite and use the correct wrenches and you should not have a future problem.
Irelands child
Old 11-02-2012, 10:51 AM
Uh, no. The single/double flare pertains to what you do with the end of the tube. It has nothing to do with the fitting. ALL 45 degree inverted flare fittings, whether brass or steel, are dimensionally equivalent. Both work. The steel are stronger, the brass don't rust and are strong enough. Your call. I typically use steel for the flare nuts that go on the tube, but the fittings are typically brass. Haven't had a problem in 40 years of doing this.
Old 11-02-2012, 11:08 AM
daveh's Avatar
Thanks guys I appreciate the helpful responses.
Dave
Brake line question wmwise Suspension - Brakes - Steering 1 09-16-2012 04:38 PM
Help with -An fitting to hard line... obengston General Rodding Tech 16 11-23-2010 08:31 PM
Another Brake fitting question monk250 Suspension - Brakes - Steering 7 03-15-2008 12:02 PM
SS brake line question-as promised techron Suspension - Brakes - Steering 3 12-26-2007 06:58 PM
Brake Line - 3 way fitting, one way only? BIGSKY Suspension - Brakes - Steering 2 11-17-2005 02:30 PM
