Heat the brass block up slightly to expand it. After it cools apply a little more PB and let it set. When you try to loosen it, tighten it slightly, then try to loosen it. Don't apply constant force in one direction. You will have to move it back and forth. The heat should not distort anything in the brass connector. You have two things working against you. The nut on the line is corroded, and the nut into the brass is corroded. Expanding the brass with heat and working with it, you will have enough flex in the line to break it loose. Then yyou wil have to concentrate on breaking the nut loose from the line. A little more heat concentrated on the nut, and a little more PB on the line to wick back. Patience will get them both loose.
You do not need the block ( new one with the kit ) so go ahead and twist. Even cut it off if you have to. Flaring a new line is not a big deal. Double flare tool kits are reasonable and should be in every HOT ROD guys tool arsenal anyway.
"I won't be wronged . I won't be insulted, and I won't be laid a hand on. " |
Also.......it is not that easily accessible..........it is located beneath the steering shaft and the car is fully assembled........This is a shot looking down from the top. The line going to the top of the pic is to the m/c and you can see the steering shaft. The nut I am having difficulty with is the one at the bottom of the block.
With something that old and in the rust belt I would just rip out all the hard lines are replace them while you are at it.
...wow all those "while I'm at it" really add up
A brass block is not going to be corroded together with the flare nut. Usually, the nut is corroded to the line.. A common mistake is to try to loosen these fittings with a constant pressure. If you do this the flare nuts go out of round and then can't be removed.
Support the block with a wrench or vicegrip so it can't move. Tap the tube wrench with a brass or hard plastic hammer in the loosen direction. usually one or two hits will do it. Then just a few back and forth turns will loosen it fron the line. |
dont know what a flare nut wrench is. Must be something plumbers use. Flare nuts are used on copper.
A tubing wrench is a heavy duty six point box end that has a slot cut in it to slide over the tube. The extra heavy side wall of the box end is to prevent spreading when force is applied. As a flare is kinda like a tapered fit, it usually takes a rap or two to get them loose from the seat. Works for frozen bleeders too. The tubing nut sticking to the line is another issue. usually, they come right loose once the flare is loosened. If it doesn't, I use a short piece if fuel line of the right i.d. put over the line and clamped with a pair of curve jaw vicegrips to hold the line while working the tubing nut loose. Applications of a good penetrating oil will help get it started. A point of interest. Have the long side of the tubing wrench pulling on the nut rather than pushing. It is less apt to round the tubing nut. |
Well......................I managed to free up the last nut without having to resort to using heat............I followed 61bone's advice and tapped on the wrench with a hammer................not heavy blows, just moderate and I finally felt it move. The line was frozen to the nut but some more penetrant along with working the nut back and forth and all is loose.
Thanks all! |
Artificial Intelligence is no match for Natural Stupidity Chet |
| Single flare Brake Lines | homesimpsonr | Suspension - Brakes - Steering | 2 | 03-20-2008 07:40 PM |
| How Does This Stuff Work? | docvette | Electrical | 3 | 06-18-2006 03:00 AM |
| Wheel clunking and brake squeal | skizot | Suspension - Brakes - Steering | 29 | 10-09-2004 06:17 AM |
| hole in brake line | 61ChevyTruck | Suspension - Brakes - Steering | 5 | 03-26-2004 01:35 PM |
| Hotrodders Knowledge Cluster: Disc Brake Conversions | Jon | Suspension - Brakes - Steering | 0 | 08-29-2003 03:34 PM |
