Brake line maintenance - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-24-2007, 11:18 PM
Semper Gumby
Wiki Edits: 2
Here's a tip:
At least once a year, do a complete, 100% flush and refill of your brake lines - all of them! I just a had a hard line rust through FROM THE INSIDE and let go. (on my 1 ton pick-up) Brake fluid is hygroscopic - it absorbs moisture from the air. I guess I had a little "bubble" of water in the line. Since fluid in the line doesn't really move (much) and mostly winds up back where it started after brakes are released, the water stayed (mostly) in one place and after a few years....
I was VERY lucky it happened when it did. I had driven to a place 300 miles away to pick up 2 big blocks for project I have in mind. Got home, parked. Went out next morning to move the pick-up, jumped in, fired her up, stepped on brake as I was putting it into reverse and "holy ####!
Brake fluid is cheap - flush 'em out guys!
Old 02-24-2007, 11:33 PM
powerrodsmike's Avatar
Wiki Edits: 161
Good advice,
The water usually settles to the bottom, that is why wheel cylinders get all rusty on the bottom of the bore after sitting for some time. I'll bet the line that rusted out was at the lowest point of a run.
Later, mikey
BE different....ACT normal.
Old 02-25-2007, 09:06 AM
weirdbeard's Avatar
1976 Ranchero GT
Last journal entry: Almost time for the first drive!
I need to right now! How can you do the job right when you don't have a monkey to pump the pedal?
Old 02-25-2007, 05:04 PM
GM Tech
Gravity will do the job for you. Suck all the old fluid out of the reservoir with a suitable device-A thoroughly dry anti-freeze tester works good for this. Then fill it with new fluid. Leave the lid on the master loose so air can displace the fuid easily and 1 at a time, crack your bleed screws and let the brake fluid run out until you get clean fluid out of them. Just make sure to keep an eye on the brake fluid level in the reservoir so it doesn't run dry. Doesn't hurt to close the bleed screws and pump the pedal vigorously once in a while. The fast moving fluid can help dislodge sc&c inside the lines. Just don't do that with the bleed screws opened or you will suck a ton of air into the system. Oh, and put the lid on the master tightly before pumping the pedal hard or it will spew brake fluid out the top all over the engine compartment
Old 02-26-2007, 12:00 AM
Chopt 48's Avatar
I did front end and brake work for over ten years in tire stores and dealerships, Taught Auto mechanics on the High school level for 13 and am 60 years old and until I started reading this board I never once heard of or read about gravity bleeding of brakes..
I'm not saying it can't be done but in 48 years of reading most all car magazines out there, taking 3 years of high school mechanics, 2 years of trade school and 40 years of experience as an adult I have never witnessed it happening. Most systems will have high spots and low spots in the lines that won't allow for such a thing.
I have had good success bleeding brakes myself using one of the mity-vac vacuum pumps with the bleeder bottle on it. It takes a lot of getting up an down to fill the mastercylinder and drain the bottle on the pump but does a good job quickly a major percentage of the time.
Plastic bodied ones are available at Sears and I think Harbor Freight has a knockoff that should work ok for occasional use.
Old 02-26-2007, 12:10 AM
Wiki Edits: 161
[QUOTE=Chopt 48]I did front end and brake work for over ten years in tire stores and dealerships, Taught Auto mechanics on the High school level for 13 and am 60 years old and until I started reading this board I never once heard of or read about gravity bleeding of brakes..
QUOTE]
Sceptic, eh?
J/K
You'll remember this thread then Gravity bleeding of brakes.
It's in the KB.
I'm still bleeding brakes the way I described in that thread. And it works better than any of them.
Later, mikey
Old 02-26-2007, 06:34 AM
weirdbeard's Avatar
1976 Ranchero GT
Dang Mikey! That sounds pretty fancy but I don't think I have the tools for that. I should just bring you my truck and you can do that vacuum bleeding thing for me. I have tried those lil crapsman vac pumps and ended up with more air in the lines than I started with.
Old 02-26-2007, 08:49 AM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Mounts
Thanks for posting that link Mikey... just had my morning laugh
I think I must have had the same guy helping me, on more than one occasion.
Originally Posted by yesgo
Sometimes it's just about the only thing to get things working when you have no pressure bleeder, esp if your pedal pumper is an idiot.
"OK ... Pump - pump - pump - HOLD"
<mutter to self> "WT F"
"Are you holding?"
"Ohhhh... <squirt> Yup!"
Old 02-26-2007, 12:14 PM
Chopt 48's Avatar
Ok, I did post on that thread.
I've always used a pressure bleeder, vacuum bleeder ( which I use most of the time now) or had someone pump the brakes. Working in production shops I never had the liberty of opening bleeder screws and walking away from the job.
There is a 3/4 ton Ford pickup out in the yard that someone else attempted to bleed the brakes on that might be a candidate to see ig it will indeed work.
Old 02-26-2007, 11:28 PM
fast68's Avatar
likes chevy trucks & boobies
the master cylinder reservoir is higher than all the lines and hoses so in theory it should all work like a plumbing drain system and be able to travel from the m/c all the way out to each wheel, completely
in theory
and flushing out brake systems is a very good thing ot do every now and then, brake fkuid only last sos long before its dirty and soaked with moisture
in which are both very bad things
good luck
Old 02-28-2007, 02:28 PM
bet on black's Avatar
hotrodder 4 life
http://www.bmw-m.net/TechProc/bleeder.htm
i just built one of these, haven't used it yet though
Old 02-28-2007, 03:18 PM
weirdbeard's Avatar
1976 Ranchero GT
That seems easy enough. Why not just use your air compressor? You could thread a male quick connect into a master cylinder cap..
Old 03-01-2007, 10:06 AM
hotrodder 4 life
well, the tank holds the new brake fluid, so it keeps the mc topped off while you are bleeding.
i guess you could hook up a compressor to the tank, but then, i wouldn't be portable anymore, that and i don't have an air compressor yet.
Old 03-01-2007, 10:20 AM
grandpaws 57's Avatar
"Don't need no V/8"-grandpaw
gravity
worked at Ford many years,On f.disk ,open bleeder one side at a time,go do something else.Takes bout 2min to get 90% air out.Don't work on cyl./drums.I use dot 5 and flush every spring.Went 12 years before needed ohaul last time
Old 03-03-2007, 07:48 PM
weirdbeard's Avatar
1976 Ranchero GT
Well I built my lil master cylinder cap with the male quick connect today. It worked very well. It leaks around the cap quit a bit. Not a problem with an air compressor but that would be annoying with the hand pump thing.
Brake line components ? Old Reb Suspension - Brakes - Steering 2 06-29-2006 05:15 PM
Caddy Brake Fun & Does Line Size Matter? Help Needed. bigfred1958 Suspension - Brakes - Steering 5 04-06-2006 08:20 AM
Brake line clamps? 302 Z28 Suspension - Brakes - Steering 3 12-24-2003 06:38 AM
Best brake line size?? Bluepen Suspension - Brakes - Steering 1 02-14-2003 02:41 PM
Brake Line Theory Turbo2Sam Suspension - Brakes - Steering 8 02-14-2003 11:46 AM
