Brake line question
Howdy, Okay dumb question. What size is the hard lines on a 1987 Chevy Suburban 1/2 ton 4x4 ? Also..what size is the brake line nut and is it standard or metic.
What I am doing is putting a Chevy 4x4 drivetrain under a 1964 International Pickup. I need to pickup brake lines and start bending. Thanks in advance for your help. There are 2 different size coming off the master cylinder, but it looks like all the wheels use the same size. |
Idiot proof
The different size fittings are so the correct ports are connected to the distribution block, correct chambers in the M/cyl to correct lines to front and back. I try to keep the M /cyl , lines and dist block all to gether and tag where front and rear hook upwhen doing a swap.
| All times are GMT -6. The time now is 04:07 PM. |
