Brake line question - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-16-2012, 03:25 PM
wmwise's Avatar
De Oppresso Liber
Brake line question
Howdy, Okay dumb question. What size is the hard lines on a 1987 Chevy Suburban 1/2 ton 4x4 ? Also..what size is the brake line nut and is it standard or metic.
What I am doing is putting a Chevy 4x4 drivetrain under a 1964 International Pickup. I need to pickup brake lines and start bending.
Thanks in advance for your help.
There are 2 different size coming off the master cylinder, but it looks like all the wheels use the same size.
Old 09-16-2012, 04:38 PM
Wiki Edits: 27
Idiot proof
The different size fittings are so the correct ports are connected to the distribution block, correct chambers in the M/cyl to correct lines to front and back. I try to keep the M /cyl , lines and dist block all to gether and tag where front and rear hook upwhen doing a swap.
Upgrade Ford 4 flat-head drive line with V8 drive line up to 1937 (mechanical brake) roundhousedog Transmission - Rearend 0 07-23-2009 04:29 PM
brake line help with a disc brake conversion novagirl74 Suspension - Brakes - Steering 3 04-01-2009 08:20 PM
SS brake line question-as promised techron Suspension - Brakes - Steering 3 12-26-2007 06:58 PM
Brake Line pat63chevy Suspension - Brakes - Steering 5 04-02-2007 07:54 PM
Copper Brake Line,Fuel Line redlightning General Rodding Tech 6 08-23-2006 08:50 PM
