Brake line removal - Is there an easy way?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-05-2002, 07:30 PM
Post Brake line removal - Is there an easy way??
I have had to replace flex hoses and brake lines on several cars and have found them to be almost impossible to take apart. I used the special wrench for brake fittings and it just rounds off the corners on the fittings. A pair of vice grips is the only way I have ever been able to get them apart and that rounds off the corners as well. Does anyone have a solution for this??
Old 05-05-2002, 07:43 PM
4 Jaw Chuck's Avatar
Post
Well Jim, I'm not sure there is an ideal solution. I use a little heat, a little tiny pipe wrench and try not to make them oblong in the process. After I get them apart I put a little never seize on the threads and then a little on the nut side of the flare so they come apart easily later.
— Han Solo
Old 05-06-2002, 05:53 AM
dmorris1200's Avatar
doesn't play well with others
Post
Yes Jim I also have found heat is the only thing that usually works. Then bleed everything out real good when done. Usually if you get the fittings hot enough a line wrench and a second wrench (if slotted) or a vise grip on the flex hose fitting.
BUILT FORD TOUGH
