brake line sealant - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-26-2011, 05:17 PM
brake line sealant
you guys know of any sealant you can use on leaking brake line fittings?
Old 04-26-2011, 05:59 PM
LATECH's Avatar
Last journal entry: GTO Reproduction Hood
NO absolutley not. They are designed to seal by means of compression on the flared surface as is is compressed between the tubing nut and the fitting. If it leaks tighten it some more. If it doesnt seal or gets worse then it is cracked or split or something. It will need reflared.
Old 04-26-2011, 06:03 PM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
If it is the fitting to a brake caliper, it may need a caliper washer if it is missing or a new one if tightened to spec and still leaking.
Old 04-26-2011, 06:56 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi
Well since no one put a quarter in the crystal ball , you'll have to tell us in detail what is leaking. And then we can give you good advice on how to repair the problem .
Rich
PS Brake line sealer
Old 04-26-2011, 07:53 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
***cringe***
Old 04-26-2011, 08:21 PM
spinn's Avatar
LAtech there is another way
. If the flare is failing to seal, get a twist of yard dabbed in liquid teflon threadloc. Make a ring of this rope, behind the flare beneath the fastner pressing the seal. Should work great for fuel, nitrous, and brake lines. This is a comon repair for old lines and compression fittings.
Old 04-27-2011, 01:20 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Never used any sealant before on the brake lines.
Cole
Old 04-27-2011, 02:23 PM
Wiki Edits: 27
dab of locktite
In the 70's Ford used a drop of locktite in the factory on some of the fittings. I don't know which spec of locktite they used. and whether it was in cars or light truck F series.
Old 04-27-2011, 02:41 PM
eloc431962's Avatar
Wiki Edits: 37
Learned something today.
Cole
Old 04-27-2011, 03:20 PM
LATECH's Avatar
Locktite on threads wont seal an inverted flare.the flare itself seals where it comes into contact with the cone inside the female part of the fitting. Locktite just keeps the nut from coming loose and indicates tampering if necessary.
National Highway Safety does not sanction using any sealer where a mechanical seal is required. It is against the law in pennsylvania and north carolina where they have safety and emission inspection.
I highly doubt any sealer would seal a brake line fitting that leaked. Even if it did I would not do it as it may kill somebody, beit the driver or another motorist. Trying to get around repairing it correctly as desinged by engineers is foolish at the least.
Fuel lines and nitrous are pipe thrtead or AN fittings. I use sealer on pipe threads.
I have never worked with AN fittings.
If a copper washer leaks on a banjo fiiting then you need new washers or thicker washers.Not sealer
Old 04-27-2011, 03:22 PM
eloc431962's Avatar
Wiki Edits: 37
I'm with you on the banjo fitting but i really never have used or seen sealant use on the brake lines before either. IMHO
Cole
Old 04-27-2011, 04:35 PM
302 Z28's Avatar
Sealant and Teflon tape is a no-no on brake line fittings.
Vince
Old 04-27-2011, 04:37 PM
T-bucket23's Avatar
Wiki Edits: 26
This horse has been beaten to death many times before. Bottom line the flare is the seal, not the threads. If it leaks the flare or the flare seat is no good or of the wrong style
Chet
Old 04-27-2011, 04:51 PM
Irelands child's Avatar
My criteria:
If it's a flared or bubble fitting, no sealant. Repair or replace.
If it's a straight fitting, a copper or aluminum washer
If it's a pipe fitting, it might get some Teflon tape if it oozes.
Ford used a blue thread locker of some sort on fittings into the wheel cylinders or calipers. My F350 had enough on the 4 caliper fittings to cause me to turn the air blue as well (also on the attaching bolts to the spindle bracket )
Dave W
Irelands child
Old 04-27-2011, 09:54 PM
Wiki Edits: 31
Any time I can't get a flared or bubbled fitting to seal from tightining, I take it apart to inspect. 90% of the time, the flare is cracked. The other 10% of the time the fitting was crossed/ bad threads. 100% of the time results in redoing the flare possibly with a new fitting..
Upgrade Ford 4 flat-head drive line with V8 drive line up to 1937 (mechanical brake) roundhousedog Transmission - Rearend 0 07-23-2009 04:29 PM
brake line help with a disc brake conversion novagirl74 Suspension - Brakes - Steering 3 04-01-2009 08:20 PM
Brake Line pat63chevy Suspension - Brakes - Steering 5 04-02-2007 07:54 PM
Copper Brake Line,Fuel Line redlightning General Rodding Tech 6 08-23-2006 08:50 PM
Best brake line size?? Bluepen Suspension - Brakes - Steering 1 02-14-2003 02:41 PM
