Brake line shutoff valve. - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 01-22-2013, 01:41 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by genr8rs View Post
I am installing a remote fill reservoir for my under the floor master cylinder. I am thinking I need a shutoff valve in the line near the master cylinder that would cut off the flow from the remote fill reservoir should I ever want to open the cover on the under floor master cylinder. Would a gas fuel line shutoff like on a show blower work for brake fluid?
Gasoline resistance doesn't necessarily equate to brake fluid resistance.
Be safe and use a valve made for the purpose: Brake Shut-Off Valves
  #17 (permalink)
Old 01-22-2013, 02:07 PM
techinspector1's Avatar
Wiki Edits: 326
I would use an inexpensive hydraulic ball valve...
PARKER V500P-4 BALL VALVE NEW* on eBay!
If you use a valve that is not specifically for brake fluid, you may want to do the research to find out if the seals used are compatible with brake fluid.
That Allstar piece that Cobalt linked looks real nice.....
Engine shutoff while driving glennsea Electrical 36 04-22-2010 08:06 PM
Upgrade Ford 4 flat-head drive line with V8 drive line up to 1937 (mechanical brake) roundhousedog Transmission - Rearend 0 07-23-2009 04:29 PM
brake line help with a disc brake conversion novagirl74 Suspension - Brakes - Steering 3 04-01-2009 08:20 PM
Crash Fuel Pump Shutoff redsdad Electrical 2 12-24-2006 03:21 PM
Copper Brake Line,Fuel Line redlightning General Rodding Tech 6 08-23-2006 08:50 PM
