Brake line size?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-20-2011, 01:45 PM
Brake line size??
I have a '39 Ford on an S10 chassis. I am using a '78 Malibu master cylinder and a Wildwood adjustable proportioning valve. I was going to use 3/16" line on the front brakes and 1/4" on rear. My proportioning valve has fittings for 3/16" only. What should I do? Is running the same size front and rear okay? Thanks in advance, Rod
Old 04-20-2011, 01:50 PM
Wiki Edits: 31
3/16" for everything will be fine. that's what the S10 originally used as does most any vehicle
Old 04-21-2011, 08:35 AM
302 Z28's Avatar
Bake line size has little to do with how your brakes operate...to a point. Go with 3/16" all around, that seems to be the standard.
Vince
Old 04-25-2011, 08:04 PM
Thanks
Hey guys, Thanks for the info. I'll proceed with 3/16" lines. Thanks again, Rod
Brake line size? Bilko Suspension - Brakes - Steering 12 05-31-2007 12:28 PM
brake line size brian berwick Suspension - Brakes - Steering 8 03-03-2007 07:32 PM
brake line size roger parsons Introduce Yourself 4 12-28-2005 09:24 AM
Brake line size??? Bad News Suspension - Brakes - Steering 5 08-13-2003 12:28 PM
Best brake line size?? Bluepen Suspension - Brakes - Steering 1 02-14-2003 02:41 PM
