Brake line splitter - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-08-2006, 05:26 PM
3100 Special's Avatar
Street Rod Dreamin'
Last journal entry: Last post project for a while
Brake line splitter
This is the stock splitter line on a 71-73 Mustang 9 inch rear. You can't see it in this photo but, there are two hard lines going to each drum screw into the block mounted on the bracket.
The rubber hose portion is gone but, otherwise my block is fine. Does anyone have experience with this particular part? What I'm trying to determine is if I can unscrew the metal portion of the hose that's still in the block. I don't have a vise and so far my attempts of holding it with vise grips haven't worked.
I might be beating a dead horse (get it? ) by trying to get this off. The only place I've looked wants 40 bucks for the whole assembly.
If it won't come off, I'd rather by a splitter somewhere and mount it to the bracket. The reason is that I really would rather have a braided stainless line going to the frame line rather than a rubber one.
Any suggestions on where to find a splitter?
Old 01-08-2006, 05:42 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Mounts
Eaton / Weatherhead makes a few different styles...
Pick the one you like here:
http://weatherhead.com/products/pdfs...-E_110-125.pdf
(Look at the second last page... 15 of 16)
HTH,
Don
Old 01-08-2006, 05:50 PM
Street Rod Dreamin'
I see one that'll work. And, it looks like there's a distributor in Pearland...right down the road.
Thanks!
Old 01-08-2006, 06:11 PM
poncho62's Avatar
Wiki Edits: 5
That is a common part, that you should be able to get at any parts store. The rubber hose wont unscrew..........
Ontario Rodders
Old 01-08-2006, 06:13 PM
Street Rod Dreamin'
A Plain Jane splitter is a common part or the complete assembly?
Old 01-08-2006, 06:16 PM
poncho62's Avatar
Wiki Edits: 5
The complete part....the braided steel line would be an aftermarket item.....probably available from a speed shop. I wouldn't bother.....the rubber lasts nearly forever.
Ontario Rodders
Old 01-08-2006, 06:23 PM
Street Rod Dreamin'
Got it.
Thanks.
brake lights stay on.... jmtw Electrical 6 03-06-2005 07:48 AM
Wound up brake hose 71gtx Suspension - Brakes - Steering 2 01-07-2004 06:17 PM
Brake line clamps? 302 Z28 Suspension - Brakes - Steering 3 12-24-2003 06:38 AM
Best brake line size?? Bluepen Suspension - Brakes - Steering 1 02-14-2003 02:41 PM
Brake Line Theory Turbo2Sam Suspension - Brakes - Steering 8 02-14-2003 11:46 AM
