brake line thru a frame, steel pipe thru frame
Has anyone ran a piece of steel pipe thru a boxed frame, welded it on either side then tapped it at both ends and use this as a brake line thru the frame? Just wondered how it works, what size pipe and any dos and donts to consider. I have seen this a few times but never tried it, and would really like to.
Thanks in Advance. |
Brake line folks SELL a part ... like this ... already made ...
I have them on my 32 ... |
Why would you want to do that? Maybe, I don't understand what you are saying.
Just run the brake line through the frame. make sure that it is fastened securly, to avoid vibration where it might wear through.
Ontario Rodders |
Speedway Motors has them( thru-frame brake line fittings)in stainless...they show two different sizes.
Dont use pipe.
If you are going from hard line to hard line, use a piece of 5/8 or 3/4" solid round, HRS or CRS doesnt matter, drill through with 3/16" , drill and tap both ends to 1/8 27 npt and use adapters 1/8 npt male to 3/16 flare. There is no good way for you to put the flared seat in your thru fitting so you are stuck using adapters. Drill a hole in your frame that fits your round stock size and weld that part in. You will probably have to chase the threads after welding, especially if you use the 5/8" The premade SS through frame adapters from speedway are 24.00 a pair. I like those. Goes from 1/8' npy to # 3 AN. I'll bet that you can find the drilled tube somewhere, I thought I'd seen them also, do a search on google. later, mikey
my signature lines...not really directed at anyone in particular.. BE different....ACT normal. No one is completely useless..They can always be used as a bad example |
Thanks for the quick responses fellas,
Highrise, Mikey, Thanks, I like those fittings from Speedway!! thats alot easier than what I was planning and accomplishes what I wanted. Thanks again |
Yep...they are easy to use and have a nice clean look. Don't have to worry about rust getting in your brakefluid either.
I have them ... from Ray Godman ... |
Those are nicer than the speedway ones, You don't have to use an adapter or a 90*
mikey
I always use them on my own stuff ... Deuce ... |
I use them front and back on my T-Bucket. They come in two different lengths, so measure twice and order once.
| Exhaust Diameter Formula | ChevelleSS_LS6 | Engine | 11 | 04-27-2012 09:21 PM |
| 84 bronco front brake line | hatebreed | Suspension - Brakes - Steering | 6 | 05-20-2005 01:28 PM |
| Brake line sizes for a id10t! | 52Caddy | Suspension - Brakes - Steering | 3 | 07-01-2004 05:36 PM |
| Running brake, electrical and gas lines with a boxed frame? | jimmy p | General Rodding Tech | 13 | 06-27-2003 08:44 PM |
| installing power brake assembly on model a frame | straycat60 | Suspension - Brakes - Steering | 1 | 02-12-2003 04:44 AM |
