brake line update - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-06-2005, 07:47 AM
Last journal entry: frame build
brake line update
The only way to bend brake line tubing. Needing a very short bend for the 27 brought to mind a improvement on the water filled line trick. I adapted my 4 ton portopower to fit the brake line. After filling the line full of jack fluid, I capped the end and pressurised the line to all the pump would pump. That figures out to about 2000psi. I experimented a bit and found I could wrap the 3/16 line around a 1/4" rod with no collapsing or kinking. Kind of a poormans mandrel bending.
DOWNSIDE At this pressure, a failure could do personal injury. Be sure to wear protective gloves and eye protection.
Old 07-06-2005, 12:37 PM
Sounds like fun. I can't say I have ever needed a bend that sharp but it might come in handy sometime.
Just make sure you clean out all that hydraulic fluid real well.
Old 07-06-2005, 02:39 PM
I use these.........they work great and are inexpensive to buy....I can get over 90 degrees with mine.....
Old 07-06-2005, 04:29 PM
[QUOTE=DeuceI can get over 90 degrees with mine.....
[/QUOTE] I can swing 360 dg and more on a 1/8" radius with the pressurised line, not that that is useful. What is, is that you can make any bend you would like with no problems.
I find most benders slightly flatten the line and don't make as tight of bend as I like.
Old 07-06-2005, 07:02 PM
abstruse dutch uncle
I'll keep that trick in mind too.
I was watching on television the making of trumpets, and they would fill the tube with water and freeze it to keep it from kinking.
Old 07-07-2005, 04:42 AM
302 Z28's Avatar
NOS, yes the nitrous people make a handy little bender that will do really tight radius bends on small diameter tubing. I used it on my 3/16" SS brake lines on my 34.
Vince
84 bronco front brake line hatebreed Suspension - Brakes - Steering 6 05-20-2005 01:28 PM
Can 2 line brake system be converted to 4? Neophyte Suspension - Brakes - Steering 8 03-07-2005 08:22 PM
Wheel clunking and brake squeal skizot Suspension - Brakes - Steering 29 10-09-2004 06:17 AM
Body Line Man586 Body - Exterior 6 08-20-2004 08:24 AM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 03:34 PM
