Brake lines - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-24-2008, 06:39 PM
Brake lines
Can anyone tell me the size of Mustang II brake lines, it looks to me like the front are 1/8" and the rear are 1/4". I am using a 1977 Mustang II master cylinder, front and rear brakes, and proportioning valve on a street rod and need to fabricate the brake lines from the master cylinder to the front and rear brake hose connectons.
Thanks
John Hawes
Old 01-24-2008, 07:05 PM
powerrodsmike's Avatar
Wiki Edits: 161
1/8 brake line is unheard of, and 1/4" is ok, but not necessary.
Remember that tube size is measured from the outside of the tube.
I use 3/16 line all the way around, and get the correct tube nut to adapt the line to whatever the port size is.
You can size the port sizes by usung a fine thread bolt,
3/16" tube uses a 3/8-24 thread, 1/4" uses a 7/16"-20 or 7/16-24. Some ports in master cylinders use even larger thread sizes, such as 1/2-20 or 9/16-18.
You local napa store should have a good selection of tube nuts and master cylinder tube nuts...if not, Speedway motors has a bunch of them .
Hope this helps,
Mikey
BE different....ACT normal.
Old 01-24-2008, 07:07 PM
kleen56's Avatar
Not sure why you have two sizes of brake line? Most vehicles use a 3/16" line for brake line. When your making new lines, make sure the ends are double flared and not single flared. Helps to eliminate leaks.
Old 01-24-2008, 07:13 PM
Wiki Edits: 161
Many stock vehicles use 1/4' in a drum brake rear for fast brake shoe retraction. And 3/16 in the front..
Many drum brake cars have 1/4" all around.
Later, mikey
Old 01-24-2008, 07:16 PM
Brake lines
It seems that I was confused by the different port sizes on the master cylinder and proportioning valve. Powerrodsmike pointed out that 3/16" line works fine when the correct sized tube nut to adapt to the port size is used.
Thanks guys---
John
Old 01-24-2008, 07:22 PM
Thanks Mikey, I have drum brakes on the rear so if I use 3/16" on the front disks, and 1/4" on the rear drums I should be OK. I have a double flaring set- up so all I need are the correct length 1/4" and 3/16" lines and should be good to go.
Thanks again
John
Old 01-24-2008, 08:29 PM
kleen56's Avatar
John, I'm running a Corvette disc/disc master cylinder on my vehicle. The outlets on it are different, as in the front looks like 1/4" and the rear 3/16". I'm using disc brakes on the front and rear, I plumbed the brake lines with 3/16" line to both the front and rear brakes. I simply used an adapter at the MC for the line connection. My brakes work fine with that combination. I am running a Wilwood proprotioning valve to the rear brakes only. My master is mounted to the firewall, so I didn't need the residual valves in the line. If your mounting the MC on the frame, you'll need the 2lb and 10lb residual valves in the lines. Hope this helps.
Old 01-25-2008, 07:05 AM
brake lines
Thanks kleen56 it gets right to the point and helps a lot.
Thanks
John
cunifer brake lines -- anyone? ford2go Suspension - Brakes - Steering 3 08-12-2008 03:19 PM
Please help me pan out this confusion with SS Brake Lines! djjc76 Suspension - Brakes - Steering 20 12-15-2007 03:58 AM
Bending brake lines anthonyc1 Suspension - Brakes - Steering 3 10-07-2007 08:50 AM
HELP!!! 39 Dodge front brake lines Madd Syntst Suspension - Brakes - Steering 3 09-23-2006 12:15 PM
Replacing fuel and brake lines adb2f General Rodding Tech 4 11-25-2003 09:29 AM
