Brake lines - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-09-2010, 09:51 AM
Brake lines
Hey guys, First time posting on this site, but i'm constantly on here soaking up all the great info everyone has to offer.
I have a 1980 Pontiac Grand Lemans Safari Station wagon. G-body. I'm doing a frame off restoration and a power train swap. Shes getting a fully forged 496 stroker and a turbo 400 trans.
but my question is, i need to do new brake lines because the factory ones were in really bad shape. I was gonna try and bend my own, but time isn't really on my side. I was looking on the site http://inlinetube.com/ . but no one makes a pre-bent brake line set up for a wagon. but they do make one for an El Camino. So what i was wondering is that if anyone knew if the brake set up for an el Camino would be the same as a wagon or not. length of lines and routing of everything. I called inline tube, but they did not know because they don't usually deal with wagons. the Pontiac wagon is a little more rare, so if you google search it, you probably wont come up with the 1980 version of it, but its just like the the 1980 Malibu wagon.
thank you to everyone in advance for your help.
Old 01-09-2010, 09:58 AM
All 78-88 A/G body cars EXCEPT the Elco use a 108" wheelbase. The Elco uses a 119" wheelbase. The brake line from the combo valve to the rear brakes will be 13" too long.
Since the wagons and 2drs use the same frame (except for some minor body mount details at the back) the 2dr brake line set should work fine.
Old 01-09-2010, 10:23 AM
sqzbox's Avatar
My pipes are my music
Hey man, the new brake lines are too easy because they bend with your bare hands. Take the old lines off and bend the new ones to match. Minor adjustments can be made during installation.
Old 01-09-2010, 08:44 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
What joe said. It would't hurt to buy a set of those coil spring looking benders, like a sleeve, they're cheap.
Semper Fi
Old 01-09-2010, 09:36 PM
thanks for all the help guys, i think i might try bending my own.. just need to find a flaring tool.
Old 01-09-2010, 11:59 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Make sure the tool is capable of making double flares.
Semper Fi
Old 01-10-2010, 04:41 AM
buggmann's Avatar
build it like you like them
Last journal entry: buggmann stilling looking
Wiki Edits: 2
buggmann
i had to make my own brakes lines for my 53 chevy 210 4 door
no one made a kit for the car it took about one afternoon to make
it i took and used my old lines to go by were to bend the lines
i ordered the line from lmc truck got a bender from advance auto
got a flare tool from autozone i made all my lines for about 75.00
hope this helps
Old 01-10-2010, 06:07 AM
artiep's Avatar
Lines
I just made brake line for my 1998 Dodge 4x4, they don't have factory lines for my truck either. You can just bend along the original line or bend up some thin wire along your frame then duplicate the wire with you brake tubing.
Old 01-10-2010, 06:21 AM
sqzbox's Avatar
ARTIEP, welcome to the site! I just did the lines on my 76 chevy 4x4 and never even thought about pre-bent. I thought all replacment lines had to be bent to fit. I got two lines the same length and even though they were about 6" longer than the one's I was replacing I just put 2 extra bends in them to make up the difference. I thought it was pretty easy actually and I'm still trying to get used to having brakes on all 4 corners! It really helps going down the steep hills when I'm out wheelin'.
Old 01-10-2010, 08:49 AM
artiep's Avatar
The lines were easy to bend but they were the standard flare at one end and metric at the other end. I had to buy a bubble flaring kit to make up the lines. Thankfully the guy that helped me at NAPA was a fellow hot rodder and knew what he was talking about when I brought in the original lines,not like the kid at PEP Boys.
Old 01-10-2010, 02:12 PM
thanks for all the help everyone, i'll let you know how it all goes.
Old 01-10-2010, 05:27 PM
Unfortunately, if you're buying premade brake lines, the ends are already flared and the coil-spring benders won't work.
Old 01-10-2010, 08:56 PM
Rickracer's Avatar
ASE Master Tech, Fabricator
Last wiki edit: Taurus 2-speed fan control wiring diagram Last photo:
I use one like this: http://www.acehardware.com/product/i...LAID=192928275
Mine is a Blue Point by Snap-On, but looks the same.
cunifer brake lines -- anyone? ford2go Suspension - Brakes - Steering 3 08-12-2008 03:19 PM
Brake lines with 37 degree AN fittings 65comet Suspension - Brakes - Steering 8 07-13-2008 06:37 PM
Please help me pan out this confusion with SS Brake Lines! djjc76 Suspension - Brakes - Steering 20 12-15-2007 03:58 AM
HELP!!! 39 Dodge front brake lines Madd Syntst Suspension - Brakes - Steering 3 09-23-2006 12:15 PM
Replacing fuel and brake lines adb2f General Rodding Tech 4 11-25-2003 09:29 AM
