brake lines - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-07-2010, 02:31 PM
peppers's Avatar
brake lines
Hi I am doing a disc brake conversion on a 71 nova, need help on the brake lines, should i use 3/16 or 1/4 inch tubing? This is the OD and it is hard to measure the OD with the flare and there is not much difference between the two. Anyone know what the original size was for power front disc and rear drum cars? Thanks
Old 03-07-2010, 05:19 PM
When you go to disc/drum you need a factory style combo valve. It is a metering valve and safety valve to separate front and rear. It has two 3/16 outlets to the front and one 1/4 to the rear. The 1/4 goes to the "T" a splits to two 3/16 to the read brake cylinders. You will need a dual reservoir master cylinder also
Old 03-07-2010, 05:42 PM
NEW INTERIORS's Avatar
Set no limit's on yourself
I run all new 3/16'' on all the cars I have built, Front to back, and never had any trouble with one..
Old 03-08-2010, 07:45 AM
peppers's Avatar
re brake lines
Big Help! Thanks alot guys!!
cunifer brake lines -- anyone? ford2go Suspension - Brakes - Steering 3 08-12-2008 03:19 PM
Brake lines with 37 degree AN fittings 65comet Suspension - Brakes - Steering 8 07-13-2008 06:37 PM
Please help me pan out this confusion with SS Brake Lines! djjc76 Suspension - Brakes - Steering 20 12-15-2007 03:58 AM
HELP!!! 39 Dodge front brake lines Madd Syntst Suspension - Brakes - Steering 3 09-23-2006 12:15 PM
Replacing fuel and brake lines adb2f General Rodding Tech 4 11-25-2003 09:29 AM
