Brake lines how often should they be replaced? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-17-2003, 06:03 PM
Jag Daddy's Avatar
1969 Mustang Coupe Project Car
Last journal entry: New Project Mustang, From Jag Daddy to Stang Daddy
Post Brake lines how often should they be replaced?
Hello all:
I have a 1975 XJ6 that has been "Lumped" (Chevy Conversion for those less in the know), I am going to be putting a new master cylinder and retro fitting the old brake resivoir with a Mitsubishi type. While I was removing the old resivoir I noticed a lot of black sediment in the bottom and the fluid was a very brown. I while I was at it I might as well order a new rear brake iine but how often should brake lines be replaced. Should I do all the lines at the same time? After all the car is almost 30 years old now. Also any advice on how to make sure the solid lines are free of junk inside?
Thanks
Mark <img src="graemlins/mwink.gif" border="0" alt="[mwink]" />
Old 03-18-2003, 04:56 AM
former member of HR.com
Post
The last time I was in the parts store, 120,000 was the recommendation. Sooner if road conditions included locations where salt has effects.
