brake lines next to headers - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-19-2006, 06:22 PM
After running all new brake lines for my new IFS I found out that
the brake line at one point is only 1/2 inch from my headers.
Maybe 1/2 inch of the line at most.
Can this cause a problem.
Old 04-19-2006, 06:24 PM
poncho62's Avatar
Wiki Edits: 5
Don't think that it will hurt, but I would move it if I could......
Ontario Rodders
Old 04-19-2006, 07:09 PM
TailGater's Avatar
Blood, Sweat, and Gears!
If there is no room to move it, you could possibly look at making a little heat shield for it, the boiling point of brake fluid isn't very high when you consider the heat that header will be dealing with.
Just my 2 cents (canadian, 1.76 cents american )
Chris
Old 04-21-2006, 11:31 PM
Rick 5150 69's Avatar
I`ve been told that it will cause high line pressure, hard pedal with no braking effect, mine is two inches away and they said it would happen, well it has`ent yet, that was three years ago, but yours being a lot closer would raise concern. Like Chris said if you can`t move it shield it !
Old 04-22-2006, 05:24 AM
Heat shield and dot 4 fluid - if it won't harm your system.
Compression fittings on brake lines fiscus Suspension - Brakes - Steering 46 09-27-2011 07:17 AM
Bulk heads for brake lines 49dream Suspension - Brakes - Steering 1 03-23-2006 12:36 PM
Stainless Steel Brake Lines Blazin72 Suspension - Brakes - Steering 2 10-27-2005 10:45 PM
brake lines too short after suspension rebuild FiveFeezy Suspension - Brakes - Steering 4 03-10-2004 09:25 PM
Trans cooler lines with headers sledge57 Transmission - Rearend 2 11-23-2003 12:51 PM
