brake master cyl question! - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-07-2006, 08:48 PM
67 Deuce 4 Me's Avatar
Bowtie or Die!
Ive searched the knowledge base but found no answer to this. I converted my 67 nova to front disk brakes. I replaced the master cyl with a manual master cyl from a 75 chevy. I was planning on changing the prop valve if I had problems. Heres the question....... which of the 2 brake line ports are used to control which 2 lines. I always thought the front port was for front brakes and the rear was for rear brakes. If so was it different in my 67, (reversed),? I ask this because the new master cyl will only fit my old lines if I swap the lines around. I hope you guys understand what Im asking, its a bit hard to explain.
Old 08-07-2006, 10:20 PM
spankys rod shop's Avatar
If one side of your master cyl. is larger,(holds more fluid) then that is your front brake side.
Old 08-08-2006, 12:02 AM
Many GM cars used the rear portion of the MC for the front brakes.
Old 08-08-2006, 12:47 AM
staleg's Avatar
Last journal entry: Hand brake
Brows the net for engine pictures of mid seventies Chevys.
Or ask on a Chevelle/Camaro Forum?
34 Chevy underfloor brake install question? hutcholdschool Suspension - Brakes - Steering 7 01-18-2006 09:25 PM
Non Hotrod Brake Question 1993 S-10 zonk Suspension - Brakes - Steering 2 12-04-2005 08:28 PM
under dash master cyl. my4848chevy Hotrodders' Lounge 3 06-20-2004 06:18 PM
Heavy Brake Pedal Question bluesman123 Suspension - Brakes - Steering 0 05-23-2004 10:41 AM
Power brake master cylinder without booster? BillyJoe Suspension - Brakes - Steering 7 02-12-2004 01:00 PM
