Which brake master to use ?
Good day All ! I'm just starting to plan out building a 1933 Chev sedan, and was going to go to the boneyard in the next couple daysto start the parts search. One of the many questions that I will be posting is which Brake system (power brake booster/master cylinder etc ) should I keep an eye out for ? I'm planning to put the master under the floor boards with a maintenance hatch, already have the Mustang II front end with a Ford 8" rearend, drums.
Thanks for any recommendations. |
I built a T Bucket and the master is under the floor. I used a 70s Vega master. It does not have power brakes. This master will turn the ports toward the center of the car when mounted with the push rod foward.
| bad brake light switch on master cylinder? | flamedfordbronco | Electrical | 3 | 07-10-2005 05:34 AM |
| Brake booster/ master cyl re-located under dash? | jimmy p | Suspension - Brakes - Steering | 6 | 03-09-2005 08:57 AM |
| Need help adapting brake line to master cylinder | RodFather | Suspension - Brakes - Steering | 4 | 01-04-2005 02:41 PM |
| Power brake master cylinder without booster? | BillyJoe | Suspension - Brakes - Steering | 7 | 02-12-2004 01:00 PM |
| Hotrodders Knowledge Cluster: Disc Brake Conversions | Jon | Suspension - Brakes - Steering | 0 | 08-29-2003 03:34 PM |
