Brake odds and ends...vendor to buy from? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-29-2006, 05:15 PM
Last journal entry: 63 split window Corvette RESTOROD
I need to get odds and ends to fit up my brakes, junction blocks (non standard blocks), stainless steel lines, spring clips for hoses, stainless steel hoses, brake line clips and what ever odds and ends I can also see that I might need.
I got standard stainless steel brake lines, then I realized that I have a twin master cylinder, so I need to drop TWO lines, one for the front and one for the rear. So I need to do some customizing.....also need a source for a brake line bending tool as well as a flairing tool.
If it wasn't easy it would be next to impossible.....I think the details will be eating me up soon!
thanks for your help, Herb
ps....this is for a 1960 Corvette with front and rear disc brakes that I am adding, Ford 9" rear, coil overs front and rear, 383 stroker, 5 speed TKO600...
Old 05-29-2006, 05:23 PM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
Here is link to what I found by typing "brake flairing tool" into the search function on this board:
http://www.hotrodders.com/forum/sear...earchid=485415
Old 05-29-2006, 08:01 PM
thanks, a lot of good leads.....
Herb
Bunch of odds N ends questions HemmiGremmie Engine 1 09-14-2002 04:09 PM
