brake pedal - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-24-2007, 01:16 AM
brake pedal
When I use the brake pedal it makes a creaking noise,
but the brakes work o/k. does it need lubrcating or is it something else.
as it is hard to get at the brake pedal.
Old 04-24-2007, 08:41 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
You can try some grease ,Vaseline or white grease .
It might need a bushing depending on the year make & model.
R
"SlowRide66"
"Illegitimis non carborundum"
Crankshaft Coalition Master List of Hotrodding Forums
Brake Pedal Placement PROBLEMS! artillerystevens Suspension - Brakes - Steering 6 01-09-2007 01:15 AM
Dual Master Cylinder Brake Pedal with Balance Bar iceman36 Suspension - Brakes - Steering 6 02-24-2006 12:55 PM
Wheel clunking and brake squeal skizot Suspension - Brakes - Steering 29 10-09-2004 06:17 AM
Brake pedal Clunk montea Suspension - Brakes - Steering 3 05-19-2004 08:34 PM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 03:34 PM
