-   -   Brake pedal goes to floor after 4 day sit. (http://www.hotrodders.com/forum/brake-pedal-goes-floor-after-4-day-sit-152953.html)
weirdbeard 02-08-2009 02:35 PM
I got back from a trip yesterday and started my 98 Yukon after 4 days of not driving it. It started fine, but when I tried to use the brakes the dang pedal sank to the floor and the brake light came on the dash for a second.
I got it home and this morning inspected and bled the brakes. Its better, but still not right at all.
The master cylinder is only about a year old. I don't see any leaks.
What could cause this? :confused:
Henry Highrise 02-08-2009 02:53 PM
Sounds like the master cylinder has gone bad...it is bypassing around the piston. Get a new master cyl. Bench bleed it and install it and bleed your brakes and you should be good to go.
weirdbeard 02-08-2009 02:59 PM
That's what I am thinking too HH. Just don't seem right cuz the M.C. is so new, but I did get it from Advance. :rolleyes:
Bryan59EC 02-08-2009 03:06 PM
Went thru about 4 of these things in the 80s on my 79.
Silly brakes only worked when they wanted to.
Scary feeling when the pedal goes to the floor, eh?
Must have got a good one last time around----still working like it shoud.
weirdbeard 02-09-2009 03:55 PM
I pulled the M.C. off today and there was brake fluid behind it! I installed another one and it seems fine for now.
It really makes me mad that they can't make these parts last longer than a year.
Just ain't right. :rolleyes:
weirdbeard 02-09-2009 03:58 PM
Oh yeah Bryan it is a scary feeling when that brake pedal sinks to the floor! My heart sinks with it every time. :eek:
eloc431962 02-09-2009 04:11 PM
i agree with Henry.i have had it happen to me .and seen it on others also.m c goes bad bypassing to the booster.good call henry. :thumbup:
flynbrian48 02-09-2009 04:48 PM
Brake fluid can ruin the booster too, so forewarned is forarmed!
weirdbeard 02-09-2009 04:55 PM
Dang! I did not even think to clean that old fluid up behind the M,C!
Now I am just imagining it corroding my dang booster..
Maybe I will just try and spray some wd-40 back there. :rolleyes:
Cape Cod Bob 02-09-2009 05:36 PM
I haven't had one apart since they were singles, but we used to just put in a new "O" ring. Maybe a little honing if needed. Much cheaper. :cool:
weirdbeard 02-09-2009 06:31 PM
I was thinking about taking this one apart to see what the heck happened during that 4 day sit.. I might just rebuild it for the practice.. Never tried that before. ;)
Henry Highrise 02-09-2009 06:38 PM
I have over the years re-built master cylinders as well as wheel cylinders. Just clean them up, hone them out, and replace the rubber cups or O rings etc. I found they did not hold up like mew ones. But then I got to thinking about it....You do take off some metal honing and increase the bore size just a tad. The rubber parts are still standard size not oversized a tad to compensate. I then quit doing it....brakes are just too important to play around with. Even the rebuilt parts. I always buy new parts and I like the name brand stuff like Wagner, etc. It might cost more but it could save your life or somebody elses.
blyne3 02-15-2009 08:17 PM
Do Not Hone An Aluminum Master Cylinder!
