I got back from a trip yesterday and started my 98 Yukon after 4 days of not driving it. It started fine, but when I tried to use the brakes the dang pedal sank to the floor and the brake light came on the dash for a second.
I got it home and this morning inspected and bled the brakes. Its better, but still not right at all.
The master cylinder is only about a year old. I don't see any leaks.
Sounds like the master cylinder has gone bad...it is bypassing around the piston. Get a new master cyl. Bench bleed it and install it and bleed your brakes and you should be good to go.
Went thru about 4 of these things in the 80s on my 79.
Silly brakes only worked when they wanted to.
Scary feeling when the pedal goes to the floor, eh?
Must have got a good one last time around----still working like it shoud.
I was thinking about taking this one apart to see what the heck happened during that 4 day sit.. I might just rebuild it for the practice.. Never tried that before.
I have over the years re-built master cylinders as well as wheel cylinders. Just clean them up, hone them out, and replace the rubber cups or O rings etc. I found they did not hold up like mew ones. But then I got to thinking about it....You do take off some metal honing and increase the bore size just a tad. The rubber parts are still standard size not oversized a tad to compensate. I then quit doing it....brakes are just too important to play around with. Even the rebuilt parts. I always buy new parts and I like the name brand stuff like Wagner, etc. It might cost more but it could save your life or somebody elses.
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
