Brake pedal Hard - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-24-2012, 11:59 AM
Brake pedal Hard
So, did a front disc brake swap on my 68 camaro. New rotors/vac booster/proportioning valve/ lines etc etc. Still have a hard brake pedal? Almost like standard non assited brakes except harder? 14 psi at booster? Any thoughts?
Old 02-27-2012, 06:31 AM
Last journal entry: Still running strong
Brake master cylinder,maybe piston inside is to big.Smaller piston less push,big piston more push.As little as 1/8 in. piston size will make a difference.
Old 02-27-2012, 06:50 AM
shine's Avatar
SPI Thug
Last journal entry: some progress
did you change the master cylinder. a drum/drum will not work on disc/drum . it takes more fluid for the disc .
68 mustang hard brake pedal rick3658 Suspension - Brakes - Steering 8 07-09-2011 03:50 PM
brake pedal hard then soft but hardly any brakes Wildwestshow Suspension - Brakes - Steering 1 12-24-2010 07:18 PM
rock hard brake pedal Deezildennis Suspension - Brakes - Steering 9 04-11-2010 03:30 PM
Hard pedal- little brake power crash Suspension - Brakes - Steering 18 01-15-2007 06:33 PM
Rock Hard Brake Pedal 64nova Suspension - Brakes - Steering 9 11-16-2006 03:34 PM
