Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Brake Pedal Has No Pressure
Old 10-08-2009, 01:04 PM
the other Mick the other Mick is offline
it could be the master cylinder.. or the booster. booster can be checked easily..
detach the master cylinder, hold it carefully in your hand and ask a friend to push the brake pedal.. try to press against boosters "button".. (what´s it called? sorry.. lack of vocabulary..) if you can hold it back, then the booster is broken..
