Brake pedal height?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-28-2007, 06:07 PM
Last journal entry: comming along
How would I go about lowering the pedal?? Would heating the arm red hot, and stepping on the brake lower it somewhat below the floor?? Also would a Mapp gas torch heat it up enough?? Thanks.. Al
Old 09-28-2007, 06:26 PM
F&J F&J is offline
Last journal entry: 32 Ford cabriolet conversion/windshield
Most old cars & trucks with that style pedal have an adjustment on the push rod. The long slot in your floor is not needed, you need only a small hole. That pedal is adusted too high.
That flat part of the lower pedal needs to stay below the floor, and some cars had a rubber bumper to hit the underside of the floor & to seal the hole when the pedal is up.
Old 09-28-2007, 06:48 PM
I forgot to tell you that the pedal assembly came from Speedway Motors.
Old 09-28-2007, 07:00 PM
This is what I have. I don't think I have very much room to to tighten up on the shaft, but I sure will give it a try.. Al
Old 09-28-2007, 08:35 PM
Youngster's Avatar
Brake pedal height
Even with the Speedway pedal, you should be able to adjust the pedal to the correct position. You might have to shorten the push rod. Just be careful not to take too much off so as to cause an over center situation. If you need to shorten the push rod, I'd make up a dummy rod to modify. That way if something goes wrong, you still have the original to work with. I have used 2 3/8 bolts with the heads cut off threaded into a long or running nut to make up an adjustable link.
Hope this helps, Youngster
Old 09-30-2007, 05:37 AM
Thanks.. That worked just fine. I was able to patch the floor, and even finish the sheetmetal work on the firewall.. Al
Brake Pedal Placement PROBLEMS! artillerystevens Suspension - Brakes - Steering 10 12-23-2013 10:47 PM
Brake Pedal ratio: manual-to-power conversion wfritchen Suspension - Brakes - Steering 2 06-21-2007 06:12 PM
Wheel clunking and brake squeal skizot Suspension - Brakes - Steering 29 10-09-2004 06:17 AM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 03:34 PM
