Brake Pedal Return Spring - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-11-2013, 03:48 PM
On a 32 Ford 3 window coupe fiberglass body, advice on how to put on a brake pedal return spring?
Old 08-11-2013, 07:08 PM
302 Z28's Avatar
There is a firm that makes a brake pedal retirn spring that goes on the M/C actuation rod. It is a clean simple install that works great.
Here a picture of one.
Vince
Brake pedal won't return Tri5truck Suspension - Brakes - Steering 2 05-31-2013 08:39 PM
Brake pedal will not return to top 57dreamer Suspension - Brakes - Steering 1 06-03-2011 02:47 PM
Brake pedal will not return cares Suspension - Brakes - Steering 4 10-06-2008 07:54 AM
Brake pedal won't return muzzfactor Suspension - Brakes - Steering 3 05-24-2007 09:58 PM
brake pedal does not return completely 49burb Suspension - Brakes - Steering 7 03-29-2003 06:34 PM
