brake pedal spongy and drops to half way before resistance
I recently bought a front disk brake conversion kit with a master cylinder and proportioning valve built in and non adjustable. The car is a 1967 firebird. The kits was for a 1967,8,9 camaro with 1 piston calipers. I bled all nearly a quart of fluid from the valves with a handheld pump. Overkill maybe but i get free brake fluid. There are no leaks. Pedal pressure was pretty good before starting engine. Master cylinder is full on both front and back reservoirs. 7" booster. Engine has 12# vacuum at idle. Has nine inch ford rear drums. Do these drums or brake cylinders require a different pressure or volume of fluid than gm drum brakes. I did not think this would cause a low brake pedal but possibly the back brakes to possibly lock up earlier than front. But the car stops ok but with much pedal travel and spongy feel. Thanks for the help. joe
