Brake pedal will not return to top - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-03-2011, 10:48 AM
I have a Cars Inc. front disc conversion with booster on my 57 Bel Air. Rear drums. Brake pedal returns fine when cars is cold, but when the engine gets up to temp. it will not return to top. Fluids are good, lines don't looked kinked, seems to have good vacuum assist off carb. Suggestions?
Old 06-03-2011, 01:47 PM
Disconnect the vacuum when it's in its stuck position. If it returns to normal, it's the booster. If not, it's hard to tell but the master cylinder would be a good second suspect. Even if the lines were welded shut the pedal would return to the top.
no clutch pedal return issue brian12c Transmission - Rearend 9 12-23-2010 11:30 PM
break pedal slow return rtyauch301 Suspension - Brakes - Steering 7 10-29-2010 09:34 AM
Brake pedal will not return cares Suspension - Brakes - Steering 4 10-06-2008 06:54 AM
Brake pedal won't return muzzfactor Suspension - Brakes - Steering 3 05-24-2007 08:58 PM
brake pedal does not return completely 49burb Suspension - Brakes - Steering 7 03-29-2003 05:34 PM
