Brake pedal won't return - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-24-2007, 11:49 AM
muzzfactor's Avatar
I'm in the process of bleeding my MC while it's on the car, but I've noticed that once I depress the brake pedal it stays there. Shouldn't it return to the upright position or is this normal? I've done away with the brake booster and I'm using a manual brake setup. I don't think it matters, but it's on a '79 Trans Am 400/4spd. Thanks.
Old 05-24-2007, 02:11 PM
powerrodsmike's Avatar
Wiki Edits: 161
You'd better check to see if the pushrod is binding in the bore. Sometimes the power brake setup has the pushrod go in on a slightly different angle than manual brakes , so when you removed the booster you may have put the MC in a position that allows the pushrod to bind against the casting or bracket. Also, check to see if you have a deep recess piston that is needed manual brakes. The MC for a power booster has a shallow recess for the pushrod in it's piston...
Later, mikey
BE different....ACT normal.
Old 05-24-2007, 04:51 PM
kc0kfg's Avatar
kc0kfg
just a thought
I just did the brakes on my 66 and they bled out ok but when i used them they did the same this I had to pull them off/up with my toe.
The cause? i had the lines backwards the front was going to the part of the master cylinder meant for the rear, sometimes its the things you least think of .
Brian kc0kfg
Old 05-24-2007, 08:58 PM
muzzfactor's Avatar
Powerrod, you nailed it, it was binding, I drilled a hole higher on the pedal and everything works fine now. Thanks.
Brake Pedal Placement PROBLEMS! artillerystevens Suspension - Brakes - Steering 6 01-09-2007 01:15 AM
Dual Master Cylinder Brake Pedal with Balance Bar iceman36 Suspension - Brakes - Steering 6 02-24-2006 12:55 PM
Wheel clunking and brake squeal skizot Suspension - Brakes - Steering 29 10-09-2004 06:17 AM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 03:34 PM
brake pedal does not return completely 49burb Suspension - Brakes - Steering 7 03-29-2003 05:34 PM
