Brake petal on the floor or on the swing. - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-27-2006, 10:14 PM
chevy3600's Avatar
http://community.webshots.com/
I am in the process of stripping my frame (51 Chevy 3600) and expect to keep the master cyl on the frame and use the existing brake petal. I will be installing disc on the front and maybe on the rear as well. Will I need to strip off the old master cyl mounts from the frame or does someone make a master cyl that mounts to the old mount?
Old 09-27-2006, 10:52 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Since you will need to be going w/ a completely new power MC, strip out all the old stuff and start fresh. Check w/ Jim Carter, Chevs of the 40s, or one of the many other Advance Design parts peddlers. I am certain they sell complete conversion kits.
Old 09-27-2006, 11:39 PM
Is this what your looking for?
http://brothersonlinestore.com/prodi...number=KORN755
Good luck with your truck.
Kim
How Does This Stuff Work? docvette Electrical 3 06-18-2006 04:00 AM
90 degree brake petal Don Meyer Suspension - Brakes - Steering 2 10-14-2005 08:44 AM
brake petal does not return dgkipp Suspension - Brakes - Steering 3 09-07-2004 05:38 PM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 04:34 PM
