Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Brake Pressure Issues,, Help Please
Old 04-13-2010, 02:17 AM
aka Duke of URL
Originally Posted by obengston
I have a 68 Camaro with the factory power disc/drum set-up. I just recently added a Moser rear end with disc brakes (SSBC brakes). I called SSBC and they said I should be able to use the set up I had.
You have a disc/disc MC (no residual valve(s))?
You should not need the metering valve on four wheel disc. You should only need a distribution block (pressure differential) and a proportioning valve. The actual brake line size(s) may need to be changed.
Remember, you are mixing two entirely different brake systems on one vehicle so modifications are going to be necessary.
What did SSBC advise on this?
