Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Brake Pressure Issues,, Help Please
Old 04-13-2010, 07:23 AM
KULTULZ KULTULZ is offline
aka Duke of URL
Originally Posted by obengston
but do I use the same distribution block??, and remove my proporting valve (stock one).
You will not need a METERING VALVE. You will still need a PROPORTIONING VALVE and ideally a PRESSURE DIFFERENTIAL VALVE.
Get with TECH @ SSBC to supply the needed parts.
Name:	MEL REGISTERED MECHANIC.jpg
