Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Brake problem
Thread: Brake problem
Old 03-16-2013, 09:20 PM
enjenjo enjenjo is offline
Originally Posted by LATECH View Post
Some GM masters did not have them. You need to find out if yours has them. Chances are it does...in the rear....but maybe not the front .
That needs some research...as you will want 10 PSI valves in the front an 2 PSI in the rear.
What bore size is the master and does it have a big and small reservoir?
That would be 10 PSI with drum, 2 PSI with disc. The Brake Man - ValveTechI
The Following User Says Thank You to enjenjo For This Useful Post:
LATECH (03-17-2013)
