Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Brake problem
Thread: Brake problem
Old 03-17-2013, 12:29 PM
RatPin RatPin is offline
Ok, I extended the shaft between MS and boster about 2.5 turns out and it did give me a nice firm pedal and brakes grabbed well. I took the truck up and down the driveway and while turning around and holding pedal firm the pressure seemed to slowly fade and go away. Do you think I need to re bleed the system now since making that adjustment? Or should I extend that shaft out another half turn? The important part is we are making progress here!
