Brake problem?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-14-2006, 09:03 AM
Brake problem??
I replaced all the brakes in my wife's Escort about a month ago. Ever since there's been a loud squeaking coming from the rear brakes at low speeds applying the brakes. The strangest part is it's only when they are cold . When they warm up, after a few miles, it goes away. Can someone shed some light on this problem?
Thanks,
John
Wilmington, MA
Old 05-14-2006, 10:02 AM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Making the assumption that you did all the mechanical work correctly=====
My guess is it is the quality of the brake lining material.
I only buy Wagner products period. Wagner Thermoquiet pads and shoes if they are available.
Most brake pads/shoes on the market are junk. Cheap is not OK.
Old 05-14-2006, 05:52 PM
Thanks, xntrik.
I guess I'll have to do them again with quality shoes this time.
Brakes that don't brake KONADOK Suspension - Brakes - Steering 45 04-10-2015 04:01 AM
74 Corvette Brake Problem iniguy Suspension - Brakes - Steering 7 07-02-2005 04:46 PM
Wheel clunking and brake squeal skizot Suspension - Brakes - Steering 29 10-09-2004 06:17 AM
brake booster vacuum problem spankthru Engine 1 06-18-2003 07:57 PM
Dot 5 Silicone Brake Fluid?? Yes or No ?? Jim Weeks Suspension - Brakes - Steering 18 04-15-2002 06:22 AM
