[quote]When I'm sitting still and push the brake petal it goes down farther than it should. <hr></blockquote>
Does it just feel lower than it should or fade to the floor if you hold your foot on it. If it just feels lower but doesn't fade to the floor it could just be your rear shoes are out of adjustment. If it fades to the floor usually that is either a hydrolic leak, air in system, or a bad cup seal in the master cylinder. A master cylinder can go bad without leaking externally. If you have any more info let us know. |
If it holds a peddle check to make sure your rear shoes are adjusted properly. Generally a bad master cylinder will result in a peddle that fades to the floor, generally.
Little trick to see if your rear brakes are out of adjust next time.(had to plow snow the other nite like this) Put the ebrake on a couple of noches till the truck wont roll now back it off 1 notch......bingo the brakes will have a high pedal and you know the rear are out of adjustment. Had to run the plow truck for about 36 hours straight like that the other day. But it does the trick.
