Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Brake Problems - Any input appreciated
Old 01-25-2013, 04:39 PM
69 widetrack 69 widetrack is offline
Faith - Respect - Trust
My bad...the part number that should work for your application is PV4...not P17....This is a common proportioning valve used in 4 wheel disc retro fits so if your not using the proper valve, this could be your problem.
Hope this helps.
Ray
The Following User Says Thank You to 69 widetrack For This Useful Post:
radconjon (01-26-2013)
