Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Brake Problems - Any input appreciated
Old 01-25-2013, 05:46 PM
LATECH's Avatar
LATECH LATECH is offline
If your master cylinder is mounted low, like under the floor, you need to put 2 lb residual valves in both systems. That helps to hold the pistons a little closer to the rotor and serves to give a better Pedal feel and height.
Check the specs on the "proportioning "valve you are running. It should be for a disc disc setup.It may (should) have a residual valve in both sides. Make sure it is plumbed in very near the master.
Early vette master cylinders use no residual valves in them.
Fact is stranger than Fiction
The Following User Says Thank You to LATECH For This Useful Post:
radconjon (01-26-2013)
