Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Brake Problems - Any input appreciated
Old 02-16-2013, 11:14 PM
aosborn's Avatar
aosborn aosborn is offline
Last wiki edit: Suspension: designs, shapes, sizes Last photo:
Wiki Edits: 7
Adding a 10lb residual pressure check valve will make the pads drag on the rotors too hard causing heat to build up. A 2lb is all that is required on a disc brake system, and then only if the master cylinder is below the level of the calipers.
Regards,
Andy
The Following User Says Thank You to aosborn For This Useful Post:
radconjon (02-17-2013)
