Brake Prop valve help. - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-10-2012, 10:38 AM
Ok all you brainiacs,
The car: 54 Plymouth, The brake system: Front, scarebird kit with Challenger calipers and dippy discs. Rear, 78 dippy drums, Hydraulics, 92 Dakota booster, master, and pedal. The problem, the dak prop valve leaks. The solutions, A- get a universal adjustable one,(the guy at the parts store said I need two, one for front, one for rear????) B-found a old rusty one on ebay that doesnt look any better than the one I have, C- get a GM one from an online hot rod supply store. And are they valved so differently they would not work? I have to make all new steel lines anyway so thats not a concern, i just want to build it once. Any thoughts Anybody???
Residual Pressure Valve BEFORE or AFTER Prop. Valve? matt2491 Suspension - Brakes - Steering 13 10-16-2010 04:51 PM
Need a source/part# for prop valve bandaid Suspension - Brakes - Steering 2 10-01-2010 02:53 AM
Source for height-sensing prop valve? joe_padavano Suspension - Brakes - Steering 14 07-10-2009 12:33 PM
Camaro 4 wheel disc prop valve RONNYinWAXHAW Suspension - Brakes - Steering 4 11-09-2006 04:35 AM
Set Prop Valve Hook up? 39chevy Suspension - Brakes - Steering 1 11-16-2003 08:55 PM
